6" lift 2008-2010 trucks
Can I get a picture of the turbine without the rag?
Also do you have a part number?
It doesn't look watercooled is that correct?
I guess the serial number does me no good I need the actual.part number you would order from TN
bigastrk
Cartersville, GA
I would have to look up the part number because it isn't stamped on it an I don't remember what it is right off hand.
It's a t-66. With the ball bearing center section. All the rest other than the exhaust housing is off the shelf. The outlet for the down pipe is 3.5" v band flange. That is the only difference that I had done.
bigastrk
Cartersville, GA
I will have to actually call turbonetics to get a part number. I just went to their site and built the same turbo hoping to get a part number of some sort but all I got was the part number for the compressor wheel setup and one for the turbine side. The actual part number isn't available for the whole turbo. So I will call them on monday if you want and see what I can come up with.
That must be why he wants a part number so it will tell him exactly what it is
If you dont mind calling monday that would be cool
Thanks again
bigastrk
Cartersville, GA
Ya I can shoot you a screen shot of the turbo as it is built minus the extra addition for the larger v band. Its straight from turbonetics if that helps.
Thanks for the pms guys I will get you shipping quotes tomorrow I was home with two sick kids today so I didn't get a chance to do it.
You should all have pms around moon tomorrow
Looks like this might need to ship in about 4 boxes?
64lbs for the springs
54 for the drop brackets
32lbs for the track bar drop and other misc parts
34 for the 4 link brackets.
bigastrk
Cartersville, GA
That's fine I understand. No worries here. I will try and get a part number from Turbonetics tomorrow for you. I wasn't sure if the website link was going to work or not.
Ok all PM's should be returned, let me know if someone didnt get one.
From the looks of it shipping is going to be around 160 bucks at the most, if you guys do not want the 4-link brackets it will save you about 30 bucks in shipping as well to, so keep that in mind if you dont want them. I do have someone interested in the springs and four link brackets but i would like to keep it as a kit.
I know the springs and drop brackets for the radius arms will fit, that's what I got them off of.
The trac bar drop and away bar drops im unsure on.
