JD3020
I got my tunes from nate, he is a good guy to deal with..... now about those injector cores that you are selling....
What about em?
Yeah. Im actually not sure who built these injectors though. I bought them not knowing what they were out of a blown motor a year ago, i was only told that they were 100hp injectors. Took em to Nate and sure enough they were 175's. Anyways i'm excited to go get em. Since i've owned truck its always ran rough and had a slight miss. I threw in these used AD's and it helped it a little but not much. Hopefully with these injectors it'll run like new, until i start breaking stuff. LOL
what else would do it? just curious
If its ran rough with 2 different sets of injectors chances are its probably not in the injectors thats causing the miss!
Thats what i was afraid of but Nate listened to it and he thinks it sounds like an injector or two not firing right. Truck doesn't use any oil and IMO the blow-by looks pretty normal. My original injectors were shot when i pulled em out, one nozzle was covered in carbon. These AD's looked good, but were pulled out of a used motor that i know nothing about. I put them in knowing they could be just as bad.
It just has a lopey idle(tach doesn't move), and a slight vibration between 1500-2k rpm's, and a slight miss at all RPM's. Runs rough when its cold, but as it warms up it smooths out. If i drive it fairly easy it generally runs smooth, if i'm running it hard it will run a little rougher. And randomly some days it will run smooth and other days its rough. IMO if it was internal issues it would be more consistent. It also can change depending on what tune i'm in or how much throttle i'm giving it.
