TERRCO
I see a blown up 7.3 in your future.
So is 4,000rpms a relatively safe rpm for these motors, assuming you have the proper fueling and timing for those kindsa rpm's?
sure...100% safe. guaranteed.
we've taken bone stock engines with bolt ons to 775hp AT 4100rpm...stock cam, stock heads, heads never removed, etc..200k mile forged rod engine..simply out of the frame, and onto our engine dyno.
I see a fair number of upgraded motors get disassembled after failure have valve imprints on the pistons..... so take that for what its worth.... you'll never change the piston to valve or piston to head clearances inside a motor and if they are tight from the factory... yep you have contact..... if they are loose from the factory and you upgrade springs and keep the RPMs moderate... then you don't have contact....
My favorite picture to show in times like this is:
And does a properly setup 7.3 shifting @ 4100 rpms produce more useable power than say, using stock 7.3 shifting points @ 2800-3100rpms?
^Ouch, thats crazy....What kinda rpm's was he spinning?
So what would you reccommend for a max piston protrusion to keep the risk of contact down in a high rpm application. I am guessing you would still need to flycut the pistons.
Explain, we still talking stock injectors with spring and p rods..... Then no.
Considering I think there was 10 miles on that motor when I got it... it doesn't really matter - but I would assume 4K. Perhaps the owner will be along to elaborate if he wants to.
Whoaaaaaaaaa 10miles?! Wtf did he have going on w/ that motor to create so much interference?
Simply RPMs - tight clearances - high boost. There is a thread somewhere in the bowls of PSN - but I have zero desire to go find it.
