Stuck again...no start and no "wait to start" light
high desert stroke
Trailer Park
The 'wait to start" light does not come on and it just cranks and cranks and will not fire. Ran perfect all day towing wood out of the forest and just **** the bed. Any suggestions would be of great help. Thanks in advance.
ghohouston
Lewisville,Texas
Pull the plug in your h.p.o. resovoir and see if there is any oil in it just for good measure. Secondly, check all fuses, if none are blown, scan it
2000wa250
No wts light generally means pcm is shot...sorry to be the bearer of bad news
Sent from my DROID BIONIC using Tapatalk 2
Jeremyleggett07
Katy, Tx.
Sounds like an oil issue.... Oil gets hot leaks and losses pressure and once it cools it thickens and runs... Just a thought
ford_trck
Vail, AZ
Sorry didn't see that, fuse 30 was good? And pull your fuel filter and check your fuel heater. That is the most common reason for no wait to start light.
high desert stroke
Trailer Park
Ok, now were getting somewhere. Last year when I rebuilt my fuel bowl the heater looked broken to me. But I didnt really care because I live in the high desert and heat is not an issue. Its always hot here.
ghohouston
Lewisville,Texas
No wts light could be unrelated. Ill bet its an ipr oring or injector orings. I would start by inspecting ipr orings/ making sure the harness to it and the tin nut are good and tight
