2wd leveling kit- 99-03
Mts678
I know there isn't many 2wd's out there. For the ones out there though- what kit did y'all order for a leveling kit? These trucks stock sit with a serious rake that needs to go! The rear is about 5" higher than the front. I have some 1" djm drop shackles I haven't installed yet, but it will still have a big rake unless I bring the front end up higher or get the drop rear hangers. And I think is rather go up in the front.
Mts678
Mts678
Ok cool. I ordered the poly kind. I have djm drop shackles that give it 1-2 inches that should level it pretty close then
Carolina444
Dallas ga
I got the aluminum 2" coil spacers from summit engendering of eBay.. I'm going to look into the djm drop hanger..
Mts678
I changed the hangers with DJM hangers....
That will be next if I think it needs to come down, I want a slight take, very slight- so when I have some weight in the bed it's not sagging. But I plan to get some firestone air bags later down the road at some point.
Mts678
I've heard that the stock shocks will work just fine. I haven't installed mine yet, I was wondering if it's a good idea to replace ball joints at the same time?
Mts678
What kinda shocks? What ball joints as well?
Mts678
Did y'all have to grind the I-beam?
qcfarmer
I did a 2" spacer. Stock shocks work but will be at max extension if you jack up front end (to change tires or whatever). I will get pics of the entire setup later
SouthFlstrokin'
I "leveled" mine up front with hockey pucks , then dropped it in the rear with 2"shackles still sat too damn high.
Mts678
Got a side pic? I have djm drop shackles but haven't put those on yet either.
Mts678
Looks pretty sweet! Damn good lookin truck!
