05+ low mount single steering stabilizer question
griz700rocket
Cisne, IL
I bought a fox single steering stabilizer to replace my factory one. I'm running stock sized tires and no lift so I thought that would be plenty. Turns out I really dislike the way it mounts. Every time I turn my steering side to side it causes the drag link to twist back and forth. Does someone make a mount for the tie rod that I can reuse my fox shock with or do I need to just go ahead and order a dual kit and another fox stabilizer?
NotStock
Tucson, AZ
To my knowledge no kit on the market uses an OEM stabilizer in a dual configuration. The OEM has a tapered stud on the end which doesnt mount as easily as a normal eyelet like what we use on our dual kit.
