Power Strokes
06 6.0 running issues
[QUOTE="Triumph1188, post: 1433623, member: 13562"] If you are burning coolant then you likely cracked your egr cooler. That whole chain of events usually starts when the oil cooler gets clogged and overheats everything downstream. Burning the coolant isn't good for cylinder pressures either. It can cause blown head gaskets. I would check to see if the egr cooler is cracked. Then probably investigate into the condition of the oil cooler. I am sure people will be able to offer a bit more insight. But those were all things I read about watching for when I purchased my 6.0 [/QUOTE]
10R140 failure
Latest: Sterling6.7
Today at 8:54 PM
2017+ 6.7 Aluminum Super Duty
D
Latest: donaldtfreeman
Today at 10:43 AM
6.0 Tech & FAQ
Latest: Tiha
Today at 8:07 AM
7.3 Tech & FAQ
Latest: ju015dd
Sunday at 7:59 AM
6.0 Aftermarket
2000 f350 dually lariat
Latest: Powerstroke Cowboy
Saturday at 8:30 PM
7.3 Aftermarket
Power Strokes
