06 dodge with triples
GreasyFingers
I'm helping a good friend spread the word on his truck. Pm me for more info. Thanks.
Ok guys, "Big Angry" is for sale. 2006 Dodge Cummins 4 door 4WD. 5.9 Cummins, Garmons stage 4 with Fat Shaft and triple disc converter, 5" aluminum rear drive shaft and 3" front, ladder bars on rear axle, 6 pt CM cage Randy's chromoly front shafts, limited slip in front as well. 18"x10"s with 305/45/18 drag radials. Motor has 03-04 Monotherms, Carrillo rods, balanced bottom end, Fluidampner, Hamilton 188/220 cam, 110 springs, and HD pushrods. Dual modded CP3's, Exergy 250 injectors, custom side port head, semi rigid poly motor mounts, dual dry nitrous kits, Huge aftermarket intercooler. Truck has a custom set of triple turbos, BW FMW billet 72 over twin FMW 67's. All trans cooler and fuel lines are braided AN fittings, 12 gal fuel cell with Fass fuel pump. Truck is EXTREMELY well built
Truck has a coolant issue, most likely a blown head gasket.
Price is $29,500, located in Salem AL.
PM me for additional details.
Sent from my SM-N910V using Tapatalk
TRUBBS
Balls Deep
Should probably link it to his thread over on CF so anyone who don't already know the history on it, can see for themselves just how well it has been built.
