08 6.4 crank no start P0A09
coley909
Pulled out of my driveway the other day got up to 40 truck shut off and hasn't even tried to start since then, cranks no start. It will not run a buzz test no communication to the injectors at all. I have over 5000 psi of fuel pressure and pump is running fine. Only code I have is P0A09 consistantly, tried returning to stock same problem returned to ******d H&S tune no difference. truck has communication to everything besides the injectors. Pretty confident it's the PCM driver for the injectors but wanted to see if anyone else has had to deal with this.
There is no info on the internet about this code if anyone has some input...
