11-15 Retrofit headlights
jwanck11
$925 OBO
Top quality components:
- Denso Slim 35W fully potted board ballasts - you can use auto setting with no issues, and they are waterproof
- MORIMOTO MINI D2S 3.0 projectors
- Apollo 2.0 square shrouds
- Osram Xenarc 66240 CBI bulbs
- OEM housings with absolutely no moisture intrusion, internal scratching and tabs are intact.
- Full wiring harness
These projectors put out more light than the new LED heads (I have them.) The width of the beam is unsurpassed. The cutoff lines are crisp. These were taken off a 50K mi truck so they are not brand new by any stretch, but remarkably in very good to excellent condition.
The lights were built so that the bulbs can be changed once they wear out - but I would not expect that to happen any time soon.
jwanck11
I did not realize you were allowed to run with a clear reflector... I know some smoke them, but I was not aware clear was legal...
Sure! I will post picts of them on the truck and post light shots tomorrow.
jwanck11
The cutoff is seen just under the window in the brick building. The drop in the line is that oncoming traffic is not blinded. That building is at least 50' away. I could usually see my lights lighting up the road in front of other cars that had their lights on ... they are that bright - even at 35W. Swap in 50W ballasts and they turn night into day. lol
http://i724.photobucket.com/albums/...A-E536-4D6E-946C-2A04613E1F98_zpsnoo8nync.jpg
http://i724.photobucket.com/albums/...A-53F0-4462-9301-2E43FE9306CC_zpsgsacvpmn.jpg
High beams:
http://i724.photobucket.com/albums/...9-78E8-4217-B4BB-C1A158ED8517_zpsl3w835pk.jpg
Low beams:
http://i724.photobucket.com/albums/...A-AF79-4E85-A54B-A3718A4D28E8_zpsnqva2xij.jpg
jwanck11
Couple of more pictures! Make me an offer.
