1995 7.3
teddy's6.0h
So I might be getting a heck of a deal on a XLT truck for wok purposes. It isn't the prettiest but I'll use it for work & a project truck. I checked the obvious thinks has a leak here & there nothing big. It doesn't have an obd2 port can I use anything to monitor it? It's gauges seem to work find but I want to double check. Any info that'll help me with anything about this truck would be good thanks. It's an f250 ext cab long bed & leveled. Thanks again! I'll be new to the obs 7.3 game. If I'm correct it's a first generation Powerstroke? Cause it was the first year for the turbo 7.3, not idi.
Justin@DP-Tuner
If it is a 95, it should have the OBDII port, it just may not be active. We can flash the PCM to a later code which will activate it. This will help tremendously when it comes to diagnosing issues.
teddy's6.0h
Sounds good, after flashes will I be able to use obd2 products to get live data, such as edge products?
Justin@DP-Tuner
You should be able to use any OBDII reader. Some cheap readers do not pull 7.3L codes or PID's, but you will still be able to connect.
