1995 F250 4x4 XLT 5 spd
rpm-inc
I bought this truck from a guy that said it had a bad oil leak. He thought it was the rear main and replaced and not very well. I brought it home and pulled the engine. Did the rear main correctly. It was leaking from the service port on the hpop among other places. Reoringed everything, including completely rebuilding the fuel bowl. It does still have a small leak from the dipstick tube. Never got around to fixing it.
New clutch. 2 new batteries. New brakes all the way around. New pads, rotors, and calipers in the front. New drums, shoes, wheel cylinders, all hardware, and e brake cables. New baby swamps injectors. 6637 filter. Trans shifts perfect. New UVCH.
Crankcase is vented to atmosphere, and it has noticeable blowby. Smokes and runs rough for a bit when first started in the morning. It has 8 known working glow plugs. Almost seems like one bank isn't getting energized? Runs perfect after 15-20 seconds.
EDIT-located outside of Chicago, 60185
I got it with a downpipe only. Has a cobbled together 4" exhaust from other projects. Exits in front of axle.
The flywheel cover is missing. The front driveshaft is out of the truck with a broken ujoint. Needs door hinge work. Body has zero rust. It is however pretty banged up, including about a 1 ft section of the bed rail cut out for some reason. Looks good from 50 ft.
AC blows ice cold, heat doesn't get super warm. Never looked into it. Fifth wheel rails installed in bed. I would drive this thing anywhere.
6k or best
cfdeng7
CT
Got a buddy looking for something similar. Where are u located
STR8LINE
Barren River Lake, KY
96 F 1 fiddy
13x,xxx miles, had 97,xxx when I bought it. Needs a bedside painted, Runs Good! Strong truck.. I put a set of 15x12" Mickey Thompson ET Drag wheels on it with 31x11.5 Interco TrXuS tires 88% .. Blows Ice cold A/C, Colder than my 07. Just put a 31spline Pos unit in it and a Nice SVO girdle thats For my Mustang pile lol ... but No BS the truck could use front wheel bearings and an alinement, an headers an a roll pan!
It is a Nice driver tho, gets around 16 mpg.. New speakers and a Pioneer supertuner III
I Also have a ZF 5spd an Transfer an All the stuff you would need, drive shafts, Harness, grommets, Pedals etc off the donor truck
Lets work somthing out, I give you cash the more I get too keep, How much?
NOTE* These pictures Suck! A buddy of mine come over an give this truck a quickOver an snapped these pics with his phone an wrote the add out.. I can tell you Alot more about the truck if you are interested.. And Will get Better pics Soon!!
http://bgky.craigslist.org/cto/3247226761.html
rpm-inc
96 F 1 fiddy
Only thing I want to trade for is cash.
rpm-inc
Cold engine all cylinders between 380 and 395. So the engine is healthy. Found a dead glow plug as well. 5500 with the new baby swamps or 4500 with an excellent set of ad's.
