Power Strokes
94-97 Tech
1996 psd help
[QUOTE="obs7.3, post: 383913, member: 4511"] did you put new injectors in it when it was swapped? what kind? used or new? clean the fuel system when it was swapped? was it cleaned or all replaced? FPR may need replaced, or could be about out of oil, should probably start with checking that being that's easiest. fuel filter can cause rough running if it's gunked up. it is also possible that the remaned IDM is no good. [/QUOTE]
GT37 Turbocharger w/10 blade turbine, billet comp.
Latest: hskfab
Friday at 1:24 PM
Engine and Drivetrain
Hard steer question/issue
Latest: psduser1
Thursday at 8:52 PM
7.3 Tech
B
WTS/WIF light flash and stall issue
Latest: blickcd
Thursday at 6:23 AM
T
2013+ steering gearbox in older trucks
Latest: TPOLO
Wednesday at 11:09 AM
J
15 cab on 08
Latest: jeretl
Jun 2, 2025
Aftermarket Super Duty 1999 - Current
Power Strokes
94-97 Tech
1996 psd help
