1999 7.3 wont start where to begin?
GDSchafer
I hope you changed out fuel filter and drained the bowl before hand. If not go pickup a motorcraft/Racor or donaldson filter and drain and clean out the bottom of the bowl as I bet its nasty.
I did drain the bowl and check the filter beforehand, wasn't dirty at all in there. Although I will still change the filter when I do the fluid changes.
TARM
Just make sure to use one of those brand filters as most others likely could be WIX or NAPA and they do not come even remotely close to meeting the Ford/IH specs for filter performance. I am not even sure how they can sell those filters as labeled for this engine and not get sued. I am willing to be if these engines still had warranties and someone had injectors go bad and they found one of those filters in there they would deny any coverage of the injectors where the fuel quality could have effected it.
