Power Strokes
7.3 Tech
2002 7.3 no start
[QUOTE="Macon, post: 1031157, member: 10768"] The truck can run on 4. Not good, and you will think something is horribly wrong, but it can run. There are way too many other things to cause a no start to jump to bad injectors. Simple check list: Is the oil within full tolerance? Is there smoke when you crank? Is the HPOP level w/in 1" of the top? Can you hear your fuel pump? Are you below 1/4 tank? Do you have gauges? if so, more to check What is the voltage while cranking? If below 10.5, you need a jump. Are RPM's displaying on your not dash gauge? If not, maybe new CPS. I can't make my '02 not start, and I never checked my CTS RPM gauge when I had a no-start position, but it may show RPM. What are your IPR and Duty Cycle readings while cranking? I'm drawing a blank for more, but that should get you started down a good path to figuring it out. [/QUOTE]
Truck slipping into 4th
Latest: Sterling6.7
Friday at 7:18 PM
6.7 Tech
Latest: DEEZUZ
Wednesday at 10:22 PM
Newly Enlisted
Latest: ghohouston
Wednesday at 9:41 PM
7.3 Aftermarket
O
2011-2016 Radiator upgrade
Latest: OtisCreekConstruction
Wednesday at 6:17 PM
6.7 Tech
Performance shops
Latest: DEEZUZ
Tuesday at 8:42 AM
7.3 Performance
Power Strokes
7.3 Tech
2002 7.3 no start
