2002 body mounts
Bmcgarvie
Port Angeles,WA
Hey guys. So was finally getting to installing my Carson stauffer t4 kit and somehow that snowballed into doing body mounts. Anyway Ford has decided to discontinue the position 4 upper body mount. I was wonder if the later 03-04 mount would work? Or if anyone knows where I can get a brand new rubber don't want poly mounts. Thanks in advance!
Kowboy
Idaho
Have you tried LMC Truck? That is were I just ordered mine last month. I have a 95 F350 and ford no longer had them available. But LMC had them all!
Bmcgarvie
Port Angeles,WA
As far a source I could see they didn't have any 4th position rubber mounts. Just poly. I ended up using a 3rd position mount and everything looks even. Also don't use the 03-07 mounts as the hole the rubber sits in is bigger unless you want to ream out the frame which i didn't.
