Power Strokes
6.7 Aftermarket
2013 Dyno results
[QUOTE="JetExpress_6.7, post: 1395849, member: 25258"] Gotcha, completely understandable on the over-spun timebomb comment too. Thanks for the clarification! Yes, entirely possible to swap in a 15 turbo. Lots of guys do it, but you might as well swap in the 15 fuel pump too while you're at it. That typically seems to be enough fuel (unless you're going higher hp, then you can do a dual fueler set up). I wouldn't worry about being boost limited tho based on Matt's comment above! [/QUOTE]
F-250 & F-350 gear ratio question ?
Latest: 6.0 Tech
Yesterday at 10:46 PM
6.7 Tech & FAQ
D
‘10 6.4 rebuild
Latest: Dieselnewb64
Thursday at 5:23 PM
6.4 Tech & FAQ
S
F-350 Dually tire size
Latest: Smokin 6.0
Thursday at 5:14 PM
6.7 Tech & FAQ
Won’t start issues
Latest: psduser1
May 18, 2025
7.3 Tech & FAQ
Windshield washer fluid reservoir
Latest: psduser1
May 18, 2025
7.3 Tech & FAQ
Power Strokes
6.7 Aftermarket
2013 Dyno results
