2017 engine swapped to a 2011
EthanCargile
There may be a thread about this already if so just point me in that direction I’m wondering if a 2017 up engine or even a 2015-2016 engine can be swapped directly to a 2011 chassis if not directly then what changes need to be made for it?Thanks in advance any help is much appreciated
Mesa, AZ
In short, yes. There is an install kit ford sells that has the new motor mounts and all whatnot for the 17 motor, as all new motors we get are 17+ motors. A 15-16 would be a direct swap, aside from little **** like the down pipe and stuff, but that would be the same with the 17 if you are swapping turbos as well.
EthanCargile
Downpipe will be an easy fix I just wanted to make sure the sensors are the same as well as the reluctor wheel and such
Depends if the truck is going to be tuned or not and if you are swapping to the new turbo
Black AOD
Ohio
Yes it can be done fairly easy, especially if the truck will be dleted and tooned
Dude I know locally spit a rod out of his 2011 lonblock and bought a whole new 18 long block and swapped it into his 2011 F250 pretty quickly and easily, I helped him with the whole ordeal.
