33 X 12.5 X 20
06fordf350
I'm thinking about buying some 33 X 12.5 X 20 tires for my 2006 F350 powerstroke. The truck is stock height. Can anyone tell me whether they think the tires will rub? Thanks
CyrusLoewen
Glenn CA
I dont think they will unless you have diffent wheel offset than factory... I think you could fit a 35 12.5 on a stock height 06 to tell you the truth.
Decker
Michigan
You will rub with 35 unless leveled. I run 33/12.50 on my 06 stock height. Pic in my Sig is with stock height with 33/12.5 on 20x9
I had zero rub or any clearance issue with 20x9 when I ran them. When I switch to 20x10 I had to pull the liner back with zip tie and and cut just a tiny piece at bottom of factory flare at the bend but wouldn't even notice unless looking for it.
