Power Strokes
6.0 Aftermarket
364.5 turbos failing recently.
[QUOTE="04cr450, post: 1262012, member: 12074"] hey charlie, the other two i saw that failed were bearing related and the one with the bearing failure also had the compressor cover literally broke in half at the outlet section.... Actually this is more or less a disappointment statement hear of what i am about to say but when i got my turbo, i believe it was from htt not sure i bought it from matt at ced- the compressor cover on the inside looked like someone took a grinder to it and didn't hold onto it possibly getting away because their were some pretty deep scuff/knick marks on the inside of the cover.. i showed matt this(pictures) and some pieces( cast shavings after you would drill and tap a hole) of the cover was left on the inside of the cover. Some shottie work if you ask me but whatever, 3k miles later its ok still. But after seeing/hearing 3 that failed and the scuffs etc on my turbo it makes me question. But to your question, i have not heard of alot of failures. Just these 3. [/QUOTE]
6.4L Ring End Gap
Latest: ncollins64
Thursday at 7:02 PM
6.4 Aftermarket
7.3 fan clutch noise
Latest: OBS-Addiction97
Thursday at 5:01 AM
6.0 Aftermarket
6
Why do 6.4 rocker arms wear out and 6.0s dont?
Latest: 6.0FinnaBlow
Wednesday at 9:00 PM
6.4 Tech
T
Mini Max Tuning
Latest: tom6mn
Wednesday at 4:23 PM
6.7 Tuning
08 F250 xl cclb project
Latest: Milesd830
Wednesday at 11:43 AM
Trucks
Derkperk
Power Strokes
6.0 Aftermarket
