468FMW and 250/100's
PABowhunter
Anybody else running a 468 with 250/100's? What kind of boost levels do you see?
I know most guys run a 200% nozzle on this turbo.
PABowhunter
That's the reason for my asking. I think something's wrong with my truck. I'm not sure if I have a boost leak or if it's something else like the hpop. I can't find a boost leak anywhere. I'll have to run some more datalogs.
FL
I know boost is just resistance in the system and all. I was thinking maybe the spearco intetcooler I put on are dropping my numbers a bit. It's a big mofo
mandkole
Northwest
the max file on the 250/1s will pull 53ish with the 42R, but it still goes to 1400F by the end of the 1/4 mi. 2900 ICP
yeah, check the data--Unless you've seen a noticeable change recently in a specific area, could be a combination of things. Having the scan gauge and looking at it enough, I'll know quickly when something isn't normal.
PABowhunter
That sounds pretty good. Especially for a stock 17* pump.
I can bury my egt gauge at 1600 when I get on it going on the highway. It's pretty good until about 2/3 throttle. Then the egts just get out of control. My icp was just under 2600 psi at around 50% dc on my last wot datalog. Not sure if that would cause that much of a noticeable egt jump.
Has anyone ever had issues with the 01-03 intercoolers with the plastic sides not holding at higher boost levels? I believe the 99-00 were metal on the sides.
Smokin 6.0
Indiana
I blew out a plastic sided Intercooler on my 02 with just a 38r. Put another one in it and it was fine for 50k plus with the same boost levels so it must just be the luck of the draw. Put a all aluminum one out of a E99 in the truck now though
FL
Low icp will cause high egts.
PABowhunter
Yea. I know. I wasn't sure if 2600 would be considered low enough to cause such high egts.
Carolina444
Dallas ga
how long can you hold 1300-1600*? Mine heats up quick do to the stock turbo but I've always been to scared to go past 1250-1300
