4r100 swap
blocknitup
Pittsburgh, PA
I have everything needed for a full 4r100 swap minus the cooler and lines. The transmission is shot it will need a rebuild. The failure was from over heating and dumping the trans fluid out of the front pump seal after being cut off during a snow storm and packed the front cooler it also didnt help it was on it way out either but that finished it off. I'm asking $800 for it all. All parts have 154k miles on them.
Parts list:
transmission
auto transfer case
flex plate w/ bolts and spacer
rear block spacer
auto trans harness
trans mount
column shifter w/boot
top column cover
prndl needle
shift linkage
E99 xle4 auto PCM
auto trans floor hump
brake pedal
dipstick tube
inspection cover
