50k maintenance
brown1
southern michigan
so i am approaching 50k and going to do some maintenance for the first time of me owning the truck. i will be losing weight and tuning at the same time. my plans are to change oil and filter, fuel filter. i was going to drain trans fluid in pan and change filter too. so my question is how much fluid should i expect to replace and do i need a gasket? may splurge and have coolant flushed while i'm at it. i bought the truck with 40k and it shows 18k of trailer mileage. the trailer was a 43' toyhauler so the truck has worked.
get ahold of jimdawg185 on here and get LE products in the engine, both differentials and the trans.. do it all at once.. LE products are badass!!
Jomax
Arizona
I'd do the coolant flush when you ****** as you have to drain the coolant anyway.
For a pan drop, you'll need about 8-9 quarts. I'd add 6 and check from there. The gasket is reusable.
04cr450
harford county, maryland
Yup. It says what to use on the dipstick.
Hmmm mine doesn't say that- hence why i asked (I looked first before asking). Oh well good deal thanks. If I was more patient I would have checked owners manual and it clearly said that lol thanks bud
Jomax
Arizona
That's odd your dipstick doesn't show it. No worries man, who has the patients to look in he owners manual?!?!
