6.0 04 issue any ideas?
kpainkiler45
Hey so my buddy has a 04 and he says when driving on the hwy if he floors it it will get to about 50 then start to " have issues like running out of fuel then if he keeps going it will die no check engine light runs fine up to that point. Any ideas what to look at or where to start looking/ what gauges to monitor fuel rail pressure or anything. Also hits 30 psi of boost then goes down after that. Thanks
08Monster
Get fuel pressure and ICP when this occurs. A scan tool can read ICP for sure, not sure about fuel pressure.
Sent from my XT1585 using Tapatalk
kpainkiler45
He says he thinks it was 29 percent at idle for the hpop double checking now
Mesa, AZ
How old is the pump? Is it early or late build? Does the exhaust still have the meower in it? Had one that threw me for a loop with a plugged kitty. It only had 2000psi at wot, but was only commanding 2000 psi.
kpainkiler45
Clean exhaust and early o4 truck had the hpop since he got the truck less than a year ago so no idea on that
Mesa, AZ
What is icp voltage koeo? You could possibly have a shorted pigtail causing the odd readings.
