6.0/6.4 starter
06Amarillo
Does the 6.4 gear reduction starter work on a 6.0. Or can I just get a gear reduction starter ? I have had my truck for almost two years and not in goin on my third starter.
Zmann
OEM they are both gear reduction the 6.4 is less of a reduction and spins faster
they both fit the 6.0 with no modification
just FYI i pulled my 6.0 starter off and bolted on a used low mile Ebay 6.4 starter at 100,000
i have never had to replace a starter i just did it for the spin factor
cRaZy8
Same. I replaced my good OEM starter at 110k with a Bosch 6.4L starter.
Starts much faster- dare I say almost as fast as a common rail......:rolleyes:
Dzchey21
wyoming
Good to hear. I have gone backwards to get one running but didn't notice that it cranked slower. Wonder how it will do in the cold!!?
Powerstroke Man 6.4
Dzchey21
wyoming
I hear the 6.7 starter is even better on these as it spins faster than the 6.4 starter.
It bolts right up also but.. it requires a bushing on the lower hole.
https://www.youtube.com/watch?v=21Wq7CeOHk0
Found out while trying to figure out if a 6.7 starter worked on the 6.4.
here is a huge thread over on fte on it with the starter specs 6.4 vs 6.7 vs 6.0 etc
http://www.ford-trucks.com/forums/1458759-swapping-a-6-4-or-6-7-starter-into-the-6-0-a.html
That's interesting. I know my 6.7 sounds much different than anything else when starting. Just thought it was the engine change more than anything.
300000 and counting
Ohio
What's the bushing for? I take it the lower bolt hole is larger then the 6.0 bolt hole?
06Amarillo
We are supposed to get a cold snap up here in the next couple days so I will keep you guys updated ! Also that top bolt behind the cylinoid was a pain in the ass ! : D
