6.0 installations
Mjoyce16
Medina, Ohio
I have a 2005 6.0 and Im going to install a 4" turbo back straight pipe, afe stage 2 cold air intake, and possibly a sct tuner sf3. What kind of performance could i get out of this?
Thanks!
Kbryant777
Plainfield,IN
Custom tunes with the tuner? With custom tunes you will see a noticeable difference in performance. If you can keep your foot out of it will see an increase in fuel mileage as well. A lot of people say the stock filter and housing flows plenty of air for what your doing right now. If your not planning going all out might be able to save yourself a couple hundred bucks.
CCRICE
Selah, WA/ Havre de Grace, MD
I've heard the same about the stock filter, kind of wish I had saved my money when I put my afe on almost a year ago and got some other mods..
Mixedbreed
Laramie, Wy
i swear i posted a reply 5 minutes ago.. anyway.
the stock filter flows around 550HP worth of air.
doubt you need it. i still have mine and i run 13.7 in the 1/4..
the sct will make you a happier man than the exhaust or intake. the exhaust will help egt's a bit.
smokedout250
harrisburg oregon
Well with studs intake custom tunes, no limit cold side kit. And 5" exhuast I made 436hp. Tuner will make you a very happy man
Kbryant777
Plainfield,IN
I wouldn't spend the money on the intake right now. If it gets to the point where you wanna make 500-550+ then spend the money on it, but if your really just doing a tuner and exhaust I wouldn't worry about it.
Mjoyce16
Medina, Ohio
Glad I could help man. Sucks to waste money on something in the beginning to find out you didn't really need it.
Im gettin my dads 05 6.0 for my first truck and have been figuring out what i wanna do! So ive been saving up and im probably going to get the exhaust, intake, and the sct tuner with tunes by innovative! And probably some rims and stuff.. So uve been a great help! Thanks man!
Kbryant777
Plainfield,IN
Don't go anything bigger then 20's unless you have a major bankroll lol. I had 22's and as much as I drive tires would kill you.
Mjoyce16
Medina, Ohio
Yeah i wanna get 20x10s will they be fine on standard height? Im lookin at XD strikes.. Yeahh tires are expensive for those haha and they have to be in load range E
Kbryant777
Plainfield,IN
I would say with 33's your probably fine. Idk with 35's you'll probably have to have atleast a leveling kit in the front. When it comes to suspension and wheels and tires I have a lot to learn.
Mjoyce16
Medina, Ohio
Yeahh ill have to figure it out! I dont wanna mess with the suspension i just wanna keep it stock and im lookin at 35 nittos with those 20x10s so ill see!
dasboot
Gooberville, Ga.
I just installed a AFE 4" TB Atlas WO/cat. It made a real differnce in power and fuel economy. I'm stock except air filter and FICM reprogramed.
Mjoyce16
Medina, Ohio
Nice man! My truck is totally stock my dad bought it in 06 and has driven it since! Its got 150,000 and im gonna drive it for as long as i can! The truck has had practically no problems besides him replacing a few injectors when it was under warranty.. What tuner did u have?
Mixedbreed
Laramie, Wy
The tunes will make or break your dads streak of luck regarding lack of issues.
I run a SCT live wire with KEM tunes. Not the only tune writer just one I chose to go with first. Soo many to choose from it is crazy. Just remember that the more you play, the more you play. I bought mine 2 years ago with 103k. Been tuned since then and now with 135k.
I tried some non custom tunes and well, it was fast but the tranny went out 3 passes down the 1/4. Be smart with your choices and make sure you need it before you buy it.
Oh and start saving now. About 5k$ will be enough to do a cab off stud job with replaced HPOP and oil cooler/egr delete.
dasboot
Gooberville, Ga.
I had my FICM reflashed or programed by PHP . Bill said it was an Atlas 40. What ever it is, I went from driving a duce & 1/2 to a finer tuned vehicle.
Bought the truck used 2 years ago 86K miles and now 122K. Runs like a champ. No problems what so ever.
