6.0 Specialty Tools
imelmo
Thought it would be a good idea to start a thread with part numbers for all the specialty tools that are good for working on 6.0 Powerstrokes like ipr sockets, hp oil testing kits, compression tester adapters, etc... I will make it a sticky once we get a good list going and then can do the same for the other engines.
So post up the tool, the part number, where you can find it, and a price.
One that saved my butt was 303-1170. It's available from Freedom Racing for about $210. It allows you to remove rocker arms without having to remove the heads or anything.
- rocker arm release tool - Freedom Racing - 303-1170 - $210
- ipr socket - Freedom Racing - 303-1112 - $30
- 14mm Semi Deep Socket (removing Torque Converter Nuts) - $15 from Snap-On
- GearWrench 3950 2-Piece 6.0-Litter Powerstroke Fan Clutch Kit - $50 on Amazon
- OTC 303-755 Disconnect Tool for High Pressure Oil Line under valve cover - $140 on eBay
- IPR Socket S6190A - $60 Snap-On
- Fuel Filter/Oil Filter Socket S3624 - $36 from Snap-On
- T40 Socket for Injector Hold Downs S6340E - $32 from Snap-On
- Head Bolt Adaptor (for getting the head bolts on the passenger side in the back) SRD35 - $63 from Snap-On
- 10mm Turbo Wrench PSWT10K - $30 from Snap-On
- mini ratchet and t30 torx bit to get the rear 2 lower high pressure oil rail bolts out on the passenger side
- Nipple Cup/Ball Tube Socket ~High Pressure Oil Rail Tool with 1/2" Square Drive & F60L-BALSKT - Amazon (HHC Diesel) - $65
PyroFighter
^^^^ this..... just picked up my first 6.0 last week. Ready to tear into it. Threads like this are life savers.
PVXCummins
PA
Just started tearing into my 6.0 a few weeks ago. If there is one thing i hate is not having the right tool for the job. So i talked to my Snap-On guy and bought what i think is the list of tools he carries for 6.0s. Heres a list of Tools I have bought so far:
-10mm Turbo Wrench PSWT10K - $30 from Snap-On
