6.0 troubles
Smokin 6.0
Indiana
Bought a 05 6.0 with a "Bad Engine".. was just messing around with it when I got it home and tried to fire on ether. It fired and ran with no funny noises for about 2 minutes and I tried to put it in drive and it died. Fuel and coolant in the oil. Has a compression skip when you try and crank it without either any direction ?
Thanks
79jasper
skiatook, Oklahoma
I mean, you bought it "with a bad engine."
So why not do some diagnosing on your own, instead of just asking what's wrong with it.
None of us have seen it, we don't know all the specifics of your truck.
Sent from my SAMSUNG-SM-G930A using Tapatalk
Mesa, AZ
Sounds like its got a dead hole. Fuel in the oil, typically means hung open injector, burne piston, burned cylimder wall, or cracked head. With the coolant in the oil as well, id be leaning toward a burned cylinder wall. Probably broke thru into the coolant jacket... Time to tear it apart...
