6.0 Upgraded Y Pipes
Worstenemy453
Fredericksburg, Va
We can do the Stainless braided flex joints in your existing Y pipe, both joints. For $100 + shipping, and can do a true bake on ceramic coat ( not some spray can BS ) for another $50.
We have joints in stock.
Wingnut
So I would have to take off the up pipes and send them to you? What is your turn around time?
Mwilbur516
Kyle, I have several guys interested in purchasing the y-pipes. Can you post up a picture and if you still need pipes sent in? You may have a good bit of GPDA business coming your way.
colo_dually
Subscribed, interested in seeing what these pipes look like, and what you get out of them.
Mwilbur516
I've seen them already and they look great. Adam will coat them in any color you would like (I chose the silver). The biggest gain comes in spool time. The ceramic coating holds the heat in as opposed to allowing it to dissipate into the engine compartment. The turbo will spool quicker which is always nice, but even nicer when towing and trying to get a heavy load moving. I'll definitely post up my findings when I get my stuff installed.
hawgdoctor
king george, va.
These are coated in the chrome ceramic inside, and out. Polished outer finish is acheived with "0000" steel wool, and hand polished from there to desired finish. Upgraded bellows with full stainless braid internally , and jig set for fitment.
Sent from my DROIDX using Tapatalk 2
