6.4 Eatting Coolant Has EGR Delete
Powerstroke Man 6.4
Here is the story the lariat I just got was low on coolant when I brought the truck home on the 27th of last month. Check it it was low. Bought 3 bottles of the ford gold coolant from ford the next day.
That day I filled here up to the cold fill line took half of a gallon.
checked it again today and its low again.
normal oil and coolant temps 190-210
no puking no white smoke no codes clean bottle no leaks 259,000 miles.
What you guys think?
Thanks in advance.
Halvy85
Bismarck, ND
Hate to ask but is it studded? Mine had a very slow coolant loss and didn't change oil color any. Oil analysis will tell you if that's where it's going though. If it is getting into your oil its not too bad of a job to get the water pump out to check the front cover.
Powerstroke Man 6.4
found the leak driver side bottom I guess I overlooked it while checking for leaks that damn radiator looks new too.
Halvy85
Bismarck, ND
Well at least it's nothing too major. Almost don't have a choice but to give alradco or mishimoto a call now :thumbsup:
EShore,MD
Yessir just went through the same thing . Ended up picking up a mishimoto in a pinch at innovative diesel . Fit and finish was perfect , the install went so smooth if it wasn't so shiny I would have thought it was stock! On a side note my coolant temps even when towing won't break 194 compared to 198-200 with the stocker.
