6.4 Head Stud Tools Possibly Wanted
bts
I'm thinking I might do head studs on 6.4 myself. Is there anyone that has purchased the tools and would like to sell them? Am I missing anything that you would recommend?
Looking for
Injector connector removal tool
Head Lift Bracket
Turbo Lift Bracket
Thanks,
CT9AIX
MA
No special tools needed for any of those items you listed. I'm assuming your going to have the cab off for this... Use a engine hoist to yank the turbos off and put them back on (just use a 10-12" piece of chain and bolt it in the center of the two turbos where they join together), just grab the heads and pull them off your self, and use a very small flat head screw driver for the injector clips. Used those methods 20+ times on 6.4's and never had an issue
78f100
Bonifay FL
Whs, if you eat your Wheaties you can lift and replace turbos by hand. I do it all the time.
bts
Thanks guys, going to try the can tilt mentioned on a couple of forums. I'll start bulking up!!
