6.4 Zf6 conversion
08 stroker
I have a 2010 F350 cc/lb and when i originally bought it i searched for weeks trying to fine one with a stick and had no luck. I haul a lot and i miss having a manual transmission. How much of a hassle would it be to convert my truck to a stick? Is it something i could bring to my dealer and have them order me a new trans ans swap them out? I have a full dpf/egr delete, studs, rcd intake and cold side pipe and mishimoto intercooler, running a mini max tuner. any help would be appreciated!
washingtonredneck
Chattaroy, Wa
I know how you feel about looking for a manual 6.4. I looked for years waiting to find my truck. I won't be much help on the swap, that sounds very expensive to have your dealer do the swap. I have factory flywheel bolts and shim if you decide to go threw with the swap.
co04cobra
WV
I should be able to set you up with everything to do the swap, or I could do the swap for you.
I highly doubt you could find any new dealer in the county to do it.
PM me with ?s or details.
