6.4L coolant wye.
BogginF350
PEORIA, IL
I have seen engines melted down because the plastic piece cracks.. $179 shipped gets you home..
stroker221
indiana
Could you put up a pic with this installed or or plastic one installed? I'm leaking coolant in the rear of the engine and I'm thinking this could be the culprit but I cant picture where this is..
03cody
Bethany Illinois
Yea I need one. I am doing headstuds and I'm glad I haven't made the trip to the ford dealer yet. Hook a brother up!
CT9AIX
MA
These are awesome. I can't tell you how many times I had wished someone made a more rugged version of that stupid plastic. Next time mine is apart this is going in for sure
Black AOD
Ohio
Do these only come in SS (it appears to be) or can they be had in aluminum as well?
Sent from my VS990 using Tapatalk
BogginF350
PEORIA, IL
Aluminum would vibrate and crack out. Also aluminum is prone to alkaline erosion. SS is the only way to go. [emoji106]
webb06
Seneca, MO
I'm still waiting to see one mounted. For the life of me I can't place where it goes on the motor.
Front driver side of engine. One end goes to coolant tank hose other goes to the heater core hose
Strokersace
Towanda, KS
Thanks for the description. Finally discovered it.
Bigger,
How can I order one of these? Are they available on the website?
