6.7 Fuel pump on 6.0?
04cr450
harford county, maryland
min pressure of this pump is 55 psi, max is 120psi so it has 1/2 inch line in and out and is high volume to boot. If you had a regulated return it would be a great set-up. This pump would be great for the 6.0 as we all know the problems with the stock 6.0 pump- is a powerful pump but lacks volume. 6.4 pump would be easier to install being that the factory plugs will wire right up to the stock 6.0 hfcm.
mint-6oh
NJ
......6.4 pump would be easier to install being that the factory plugs will wire right up to the stock 6.0 hfcm.
the 6.4l electric pump is low pressure and could only be used as a lift pump for a 6.0l and not a replacement
mint-6oh
NJ
ok. I read your post that you were talking about replacing a 6.0 pump with 6.4 pump the way you were talking about using the factory wiring
