6.7 Timing Calculator
ABMax24
Grande Prairie, Alberta, Canada
Here is a copy of my 6.7 Excel Timing Calculator.
Green Tabs are data entered from your current tune.
Red tabs are calculated values from your current tune.
Yellow tab is for your desired BTDC injection amount.
Blue tab is for the resultant timing table based on all existing tune data (fuel pressure, injector pulse width, etc) and your desired BTDC timing percentage.
I have renamed it to a .xls file because it won't upload the .xlsx format, for proper functionality change back to .xlsx prior to opening file.
Hope this is of some use to some of you.
  • Timing Calc 6.7.xls
