7.3 head gasket recomendations
bsmall
Hi i am in the process of doing a frame up build on a 1997 obs f350. I have got the short block back from the machine shop and getting ready to do the heads. I plan on running a irate diesel t4 set up with the 369sxe turbo and 250/200 injectors. This will just be a fun truck maybe dyno/strip once a year looking for head gasket recommendations
Magnum PD
VA
Stock gaskets are fine, better use ARP studs. You can also use cometic gaskets.
