7.3 issues? still smoking....
rockcentral4wd
I bought a truck... it was idling rough and not running great... he put injectors in it last year and an IDM the day i bought it. Took it and had it scanned, it came up with a cylinder 5 misfire code. while idling it will smoke and smells strongly like fuel out the exhaust. if i unplug injector 5 it quits smoking.
replaced number 5 injector... idles smoother but still smokes... if i unplug cyl 5 it will get better. when i drive the truck sometimes it will plume lots of smoke and sometimes it picks on up like it wants to go but still hesitates slightly...
im kinda stumped and any help or direction would be greatly appreciated!!!
its a early 99 with 158k miles...
rockcentral4wd
No I haven't done a compression test yet because I couldn't see how that would cause the over fueling smell and since when I installed the new injector it solved the rough idling issue but I could be wrong.
TrailerHauler
Michigan
I would do :whs: and a compression test.
You said the smoke went away when you unplugged the injector, and the smoke smells strongly of fuel... That injector may be firing and working properly, but the cylinder may not be burning off all the fuel. That's why I suggest a compression test, low compression won't burn all the fuel.
TARM
Already replaced the injector and it stayed with the hole. SO injector is not the issue. But if the old injector was dumping tons of fuel............I am with these two compression test that hole.
If you have a hole in your piston or some other reason for no compression that fuel is not exactly combusting but instead the raw fuel could be dumping out the tail pipe.
silverpsd_06
Wellsville KS
And replacing an injector doesn't necessarily rule out a faulty harness. Either way I would do a compression first before you go throwing a new harness at it. If it comes out ok then I'd start pointing my finger at the harness
rockcentral4wd
Ski guess you would consider 200 psi with oil in the cylinder to be good right?(sarcasm for those who may have missed it. Lol). It only tested 100 the first couple times. I almost feel like I wasn't getting an accurate reading. I don't feel like my adapter was sealing properly.
Going to see if I can find another tester and try again but I think I'm still ultimately going to get the same result! FML
TARM
spray some soap water around the insert and that will tell you if you have a good seal. Did you test more than one cylinder?
rockcentral4wd
I cranked it over several 5-6 times and it only got just above 100 then back the adapter out added some oil and got over 200! My adapter would start in the hole and then stop about 5-6 turns in and get tight. It didn't want to thread all the way in and I didn't want to make it in fear of cross threading but it appears that I may have done it anyways! FML. So I stopped and will reevaluate again since it got dark on me. Thanks for the input guys.
stroker2
Durango/Fort Collins, CO
Doubling that pressure just with oil im pretty sure means you have a slight leak either past the rings or valve seats or possibly through your adapter if it was cross threaded.
TARM
Yep could be anything. You need to get a good seal as you know on that adapter. Maybe the adapter threads are damaged up at the point where it started to get hard to thread. Look at it and if so you can run a nut or better yet a die to fix those threads.
rockcentral4wd
The glow plug will thread all the way in but I am losing pressure around the adapter. I even tried putting some Teflon tape on it to make it seal but didn't work. I tested the cylinder 3 and it seats and threads fine into it. Who knows. I tested it last night motor cold with about the same results but I did notice that my overflow bottle released pressure when I took the cap off. I didn't think that it should have pressure since I haven't run the truck since Thursday but correct me If I'm wrong?
