7.3 model year identification & rod check
skooter_built
Hi guys,
I found a great deal on an almost complete 2001 7.3 that I want to use for a performance rebuild. Is there anything on the engine that I can use to date it? Just wanna make sure I get what I'm looking for and not pick up an older 7.3.
Also, finger's crossed hopefully this is a forged rod engine, are there any quick ways to check if it is?
Layson
no don't look at the numbers. You gotta pull the plug to check. You never know who's valve covers are on that truck or anything that has happened to it.
Only way is to look. Honestly it is real easy to do!
skooter_built
Got ya thanks! As for the block, are there any numbers, traits or anything else that I can look at to confirm an 01 or a SuperDuty 7.3 and not an OBS 7.3?
ghohouston
Lewisville,Texas
It doesnt matter if its a super duty or an obs motor, they are the same blocks, bracketry will swap over if it was an obs motor
Lowdown89
Travelers Rest , SC
Yeah there's not much difference in a OBS engine and a newer one not to mention the OBS will have forged rods so you don't have to guess at wether or not the 01 engine will have them
dentexpowerstroke
denton, tx
My old motor had a forged rod serial number and it really had pmr, pull the plug and check. That's the reason I didn't just post what serial numbers to look for.
