7.3 parts
oldbluef250
Alma Center, WI
02 7.3 motor. Includes heads, penlums, and all the internals. PMR rods. Has an oil pan but it is rusted through so it will need to be replaced. Ran good before it was pulled about a month ago - $300
gtp38 turbo. Very minimal shaft play, wheel is in good shape - $175
2 sets of SD up pipes. Includes collectors - $50 a piece
stock 4r100 tranny cooler - $40
turbo pedistal - $40
Oil cooler off of a van - $35
Flywheel and pressure plate w/clutch off of 95 psd - $100
Manual transfer case off of a 95 psd zf5. #1356 - $125
Or just take it all for $700
oldbluef250
Alma Center, WI
Yeah. There is a small piece that broke off of the hpop where one of the bolts go through. It happened when I was taking it off the motor. It still works fine and the piece is getting welded back on right now. $150 for it once I get it back from the welder.
