7.3 Triple Turbo Complete engine
Beau
Buffalo, MN
1995 7.3 with 84k original miles on engine, with accessories , water meth setup two 1000cc nozzles, about 500 miles since build
Balanced crank with arp main studs and girdle, Carillo Rods, Mahle pistons ceramic coated tops, teflon skirts 15.5:1 compression 0.10 over. Diesel site high volume LPOP. New lifters, stock cam.
Smith brothers pushrods, with Beehive valve springs, Gen3 HPOP with a stock HPOP below it. Farmers 400/200 injectors, Arp head studs with hypermax wire ring kit and head gaskets, Turbonetics bb 66mm primary, turbonetics bb 82mm secondary with ceramic coated hot side and a precision pt 94mm with ceramic coated hot side. Two precision 39mm gates and one 46mm gate, 22psi rise in-between stages before dump. Extra springs come with, Tuning by Matt at ******** on a PHP Hydra. Regulated Return system Irate comp setup (Fuel Lab).
I have a lot of money in this, asking 12,500 obo. Located in Buffalo, MN.
Would like to sell whole, but will part out if it comes to that.
Thanks,
Beau
Buffalo, MN
Part Out
Carrillo Rods with pistons: 1200
Injectors 400/200 : 1000
Arp Head Studs : 100
Smith Bro Pushrods : 100
Fluidamper OBS : 200
Intake Plenums : 100
Beehive valve springs/retainers seals : 200
Main Girdle and studs : 300
Gen 3 : 600
Dieselsite LPOP : 250
Turbonetics BB T66 3" v band flange .81 a/r : 300
Turbonetics BB 82mm with ceramic coated turbine 1.14 a/r : 800
Precision PT94 with ceramic coated turbine 1.32 a/r T5 flange : 1000
Waste gates 38mm X2: 100 each with springs - no flanges
Waste gate 46mm with springs: 150 no flanges
