7.3 water pump w/filter
Peroni
North Carolina
Do they work on an obs?
The actual pump and hardware will work in the OBS however the lower hose will be different. Check out the write up sticky in the OBS aftermarket section.
Jennifer I do hope Dieselsite will show some love to the OBS and offer a high quality lower radiator hose to work with this pump. :poke: IIRC this mod has been fairly popular with the OBS guys going back to at least 2006. Be nice if we weren't reduced to using a Dodge or generic flex hose on our trucks.
PSD POWER007
Columbus, GA
The description says that it won't work on dual alternator set ups...will it work with the dual alternator upper radiator hose? I sure hope so! This is definitely on my "to do soon" list!
Jomax
Arizona
It does in fact work with a dual alt upper hose, installed one myself.
Dieselsite
It will work with the dual alt upper hose. It just won't work with the actual second alternator in place.
The OBS version is absolutely in the works. Look for updates on that project in the next month or so.
Bob
Freightshaker
Evansville
Can just a lower hose be purchased? The hose I am running is sleved and close to steering components. A nice fitting hose would be nice.
A true accomplishment would be a solution to allow them to work on a dual.alternator truck. I wonder if that long horn could be cut off, tapped, and a 90° elbow installed to allow.clearance?
