7.3ebp question
08Monster
I have a 2001 7.3 in my shop, it has a code for ebp faults, and the ebp reads 52-52.9 at idle, engine off, full throttle, etc. Voltage is a constant 4.9.
Unplug and sensor goes to 42.9, voltage 0.
Faulty sensor?
Sent from my Moto Z (2) using Tapatalk
Magnum PD
VA
Take the plug off the sensor, see if there is continuity between the wires with an electrical meter. If they are crossed it’ll tell the computer that it’s max exhaust back pressure.
08Monster
If that was the case, when I unplug the sensor, it should still read max. Correct? Beings the reading changes when I unplug, seems to be a sensor
