95 gauge cluster
rpm-inc
How is this thing supposed to act? The fuel gauge works, but it does not go to empty when you shut the key off. Is that normal?
Also where does the pcm get ect from? After driving fairly hard for a few miles, the gauge was hardly in the normal and ae says it was only 70 degrees. When cold it was 37 and that was 20 degrees cooler than ambient.
I guess that could just be the sensor, but seems strange the fuel level stays put when you shut key off. Also the voltmeter likes to move around every once in a while. Never did it when I had ae hooked up, though. New alternator installed was originally 14.4-5 and today it was 14.1-2 according to ae and an actual voltmeter. Batteries are a week old.
brewer
Yes, that's how the fuel gauge should be.
ECT comes from the coolant temp sensor connector on top of the water pump next to the thermostat housing. When you say "hardly in the normal", what do you mean? These trucks seem to all run at different temps, none are exactly the same. Normal operating temp on the guage should show somewhere from just below the N to the O or the R, but most are right around the N.
rpm-inc
I forgot the pcm does not read ect. It is for the gauge only. I did monitor eot and it was 195 driving it pretty hard so all is good there.
Good to know about the fuel gauge. Thanks.
