zilla68
Trying to help a friend diagnose his truck over 1200 miles away.
1997 ford 7.3
I had the Cam position sensor replaced and that fixed my issue with it jerking and dying. It smokes alot and also will put out a grayish white smoke intermittently. It has never been the same after I broke down the other year. They replaced the HPOP and the rings on the injectors. Since then it has smoked. It is really bad when I tow my trailer. The funny thing is that if I get it wound up around 3k rpm it stops smoking. It's bad between 2-2500 rpm when towing. I was told that the guys who did the orings probably didn't replace these cups that the injectors sit in and they should have.
Any ideas on the smoke issues? I know not much to go on, sorry, but I'll get more info.
Any good repair shops near San Jose California?
1997 ford 7.3
