Abd issues
ckrueg
Belding MI
Last year my abs light came on and I read the codes and got c1145- right front circuit failure. I recently replaced my knuckle seals and u joints and decided to replace the sensor thinking it would fix my problem. Well it didn't and after some research I realize this code is the one thrown when the circuit is bad, as if the sensor isn't plugged in. I tried unplugging the left sensor to test and got the same code for the left side. I checked the plug and it looks clean and the wiring back to the rear sensor appears to be intact. Any ideas what could be the issue?
