Advice please
Rico
San Diego
Well, I have coolant In my oil again but no steam out the exhaust pipe or manifolds. Heads were recently magnaflexed and gaskets are new with studs. Injectors have about two years on them. Oil was very gooey at my last oil change and under the valve covers there was a milky residue. Truck got dropped off at the mechanics this morning and they did a look over. PCM is readin the oil at 253 degrees but the oil temp sensor is reading none of that. Mechanic is going to give me a price for a tear down to inspect the heads but I can can do all of that work myself except for having a engine hoist. I’m waiting for the price but anticipate that it’s going to be expensive. What are your thoughts? I could have been driving with coolant in the oil for the last 3000 miles since I replaced the oil cooler and added an oil bypass system. My last oil change showed no signs of coolant
Rico
San Diego
Also the mechanic shop asked for $400 to do a “complete” compression test. Is it a good idea to run this test?
gnxtc2
Bergen County, NJ USA
Why were the heads removed originally? Drain the oil and pressurize the coolant system and checks if any coolant runs out of the pan.
Just FYI, coolant eats the bearing material. Remove the coolant for now and run straight water.
Billy T.
gnxtc2@aol.com
Rico
San Diego
Thanks for the responses. The coolant seemed perfectly fine but the oil not so much. I went ahead and gave the ok for the compression test.
The heads were originally removed due to coolant getting everywhere and steaming out of the tail pipe- new cups injectors and so on. Wish
I had the knowledge of doing a compression test then. Anyhow that was two years ago. I did recently replace the oil cooler and add an oil bypass to the oil system.
My compression test from the mechanics shop:
1-360. 2- 400
3-360. 4- 355
5-380. 6- 380
7-380. 8- 400
The shop wants $1800 to remove the heads then inspect. Cost includes new gaskets and reinstall. Torn on what to do.
Rico
San Diego
So the shop is going to give me a price for a reman short block before any more work is done. I asked about a leak down test but don’t remember what the owner said. If that is the end result would a 97 block work with the 95.5 heads if they are still good?
boggerr
Barnegat, N.J.
How long has the head job been done and how many oil changes have you done since the head job?
How long did you drive with coolant going into the oil before doing the head job?
Rico
San Diego
Head job was 2 yearsago and about 30,000 miles worth of oil changes. Just noticed jelly oil last oil change
boggerr
Barnegat, N.J.
Ah ok, thought it was recent.
I would do what Billy said and pressure test the system with the oil drained. It’s kind of odd that you didn’t see a coolant loss
Rico
San Diego
I did see a coolant loss but it was hard to tell since I just installed a new oil cooler and a oil filter with hoses that I Teed into the heater hoses with. Was hard to tell
m j
BC Canada Eh!
go to a different shop. no need to replace the motor or pull heads without proving there is an issue with the heads.
throw that coolant filter away, remove the oil bypass thing.
pressure test, find the coolant leak.
Rico
San Diego
There was going to be a leak down test but the shop didn’t want to move forward for some reason. Anyhow compression test didn’t look good. Might get truck towed back home but I’ve got to get to work.
Rico
San Diego
I have. I think I’m goin to remove the oil filter and pressurize the coolant. Could be that the rear oil cooler mount isn’t sitting correctly? The oil cooler and filter mount are brand new oem parts
Rico
San Diego
Well spoke with a mechanic friend of mine and he thinks that hitting 30 lbs of boost with my stage 1.5 injectors if too much for a stock motor and that I’m going to need to upgrade to a performance long block if I want to have good life out of a motor. Opinions?
Rico
San Diego
Yea my buddy is more of a carburetor specialist but he has lots of experience( 35+ years). Just deciding what to do from here. Compression didn’t look good.
