amada ha 250 band saw issues
superpsd
Missouri
Sorry its a little late but I use to work on the 250 and 400 saws. I worked for a company that ran them all day long and the had there issues. But the worst issue is the cost of replacement parts from amada. Check the limit switches they like to get a little sticky. Lube the switch up and clean them out. Also the pulse coder track can get packed with shavings over time and the coder toothed wheel will run on top of the shavings and skip time. Your problem may also be the dirrectional control valve itself. May want to manually operate the spool.
AltPartsInc
Bellport
alternative solution for Amada manufacturing equipment parts and services. We provide high-quality parts tooled to the original OEM specifications, but at a significant discount to you, the customer.Our parts offer the same high performance and reliability as Amada America- OEM parts. We know Amada products inside and out, and we appreciate their quality just as you do.
amada parts
