PsRumors
I used one years ago on a Dodge due to a badly worn rag joint and it was top quality. But here is the issue I am chaising.
Ever since installing the D60 I have a very slight wander. The steering wheel has just a slight play which is the cause but I can't get the last bit of excessive play worked out. The wheel has enough play to go from the 12 to 1 position, probably a little less than that.
When I installed the d60 I used new BJs, bearings, bushings, tie rods, etc. The track bar is installed also with new bushings.
With someone turning the steering wheel I cannot detect any play anywhere but riding down the road it is there.
I have also adjusted the steering box per the service manual.
