B code vs carli mini packs.
FrankTheTank
Cecil County, MD
I'm looking for first hand experance in ride quality of stock 05-07 rear spring being changed to 99-04 B-codes...........NOW, the real question is the ride compareason of B-codes vs the 05-07 springs with the bottom leaf replaced with carli's progressive rate mini pack. The 05-07 spring I have came out of an ext cab short bed so they should be a lower weight rating.
Not worried too much on towing as anything I do is under 10k but factor that into the equation also as I do tow under 10k often
powerlifter405
Butt Town
IIRC this was a topic on PSN and I talked to someone doing a swap and letter mentioned he went w/ the deaver rear replacement pack it that was the way to go if money allows.
