Power Strokes
94-97 Tech
Bad injectors?
[QUOTE="MAFoElffen, post: 963591, member: 14847"] One or two dead, I would say other things. 4 dead, bigger problems that narrows that down. You already checked the wiring and electrical going to and from the injectors, so electrically, there are sound. Since it is the whole bank on one side, it could be one of two things... -Check to see if you have HPOP pressure in that bank... A reading of ICP pressure is from that head... Just to ensure you don't have a leak dumping pressure in that head... That is not likely, but is good to rule out. ***More likely with all 4 injectors dead in one head would be a diode blown in the IDM. You could check if you where getting sense voltage by putting in noid lights, but since most don't have those... I agree-- Call Swamps and tell them what is going on. [/QUOTE]
O
F-250 & F-350 gear ratio question ?
Latest: Obe
Yesterday at 11:02 AM
6.7 Tech & FAQ
D
‘10 6.4 rebuild
Latest: Dieselnewb64
May 22, 2025
6.4 Tech & FAQ
S
F-350 Dually tire size
Latest: Smokin 6.0
May 22, 2025
6.7 Tech & FAQ
Won’t start issues
Latest: psduser1
May 18, 2025
7.3 Tech & FAQ
Windshield washer fluid reservoir
Latest: psduser1
May 18, 2025
7.3 Tech & FAQ
Power Strokes
94-97 Tech
Bad injectors?
